Wyze Surge Protector
Power for the modern home.
Low stock: 53 left
$9.99
OR
Power for the modern home. This surge-protected power strip has 3 USB ports and 3 grounded outlets for your devices to plug into.
3 USB ports
Total 5V/3.1A, each 5V/2.1A max.
3-outlet surge protector
With 268 joules suppression rating
Flame resistant
Safety first! Flame retardant to 1,380℉ (750℃).
Low profile design
Slim design with right-angle flat plug and 4 non-slip rubber pads.
Color
- White
Dimensions
- 8.58″ (L) x 1.61″ (W) x 1.02″ (H)
Weight
- 0.89 lbs
Power
- AC 15A, 125V, 60Hz, 1875W
- 4ft Power Cord (14 AWG)
- 20µA ground fault protection
Additional Details
- 3 USB ports, total 5V/3.1A, each 5V/2.1A max.
- 3-outlet surge protector with 268 joules suppression rating
- Right-angle flat plug
- 4 non-slip rubber pads located on the bottom
- Soft-white LED light indicator
- Scratch-resistant
15A Overload Protection
- Product will automatically switch off when the current reaches its limit and a manual reset is required for reuse.
Flame Retardant
- Up to 1,380℉ (750℃)
Certifications
- UL and FCC certified
Warranty
- 1-year warranty
- Wyze Surge Protector 1x
- Quickstart Guide 1x
No, the Wyze Surge Protector is not IoT (Wi-Fi) capable. If you're looking for a smart plug that enables you to control connected devices remotely, please take a look at Wyze Plugs for indoor applications and Wyze Plug Outdoor for outdoor uses.
Yes. Here are a few facts that most customers ask about.
- Outlets tested to be plugged in over 10,000 times.
- Flame retardant up to 1,380℉ (750℃)
