Wyze Sense Keypad
Wyze Sense Keypad
Disarm your home security remotely.
⚠️ Requires Wyze Home Monitoring.
This device will NOT function as an individual or standalone product or with Wyze Sense v1.
Place the Wyze Sense Keypad anywhere in your home to arm and disarm your system quickly or send first responders with on-device emergency button.
$19.98
Disarm your home security remotely. Requires Wyze Home Monitoring.
20ft Cable Length
Compatible With Many Wyze Cams
Easy to install
IP67 Weather Rating
No. Wyze Sense Entry and Motion Sensors and Keypads are for indoor use only.
No, the adhesive is designed to be permanent.
No, all sensors and keypad will require a central device to pair with.
Up to 100 sensors & keypads.
There is an emergency alarm button on the side of the Wyze Sense Keypad to call first responders. You cannot talk to them through the keypad.
